niwat
Jul 19, 2020Aspirant
Rax Wifi set up
i has new ipad pro 2020 support wifi6, HT 80 mimo 4x4, I just bought rax200. My home ethernet lan is 1000/500 Mbps (my ipad far from router just only 5 m) The problem is wifi speed not stable and...
Christian_R
Jul 22, 2020NETGEAR Employee Retired
Hello niwat,
If you recently purchased the device, I would suggest contacting our support team as your device is provided with 90 days of complimentary support. They will be able to assist in optimizing your settings for your network.
https://www.netgear.com/support/default.aspx
Christian
niwat
Jul 22, 2020Aspirant
Thank you
