Philippe29's avatar
Philippe29
RAX10 - How to separate 2 networks ?
Bonjour,
J'ai acheté un routeur RAX10 pour créer un réseau séparé en 10.0.0.xxx du réseau principal de la Livebox (192.168.1.xxx).
Tout a fonctionné sauf que connecté au réseau en 10.0.0.xxx, je peux pingué la box qui est en 192.168.1.xxx.
Je voudrai qu'aucun appareil ne puisse accéder au réseau en 192.168.1.xxx.
C'est à dire isoler complètement le réseau en 10.0.0.xxx distibué par le RAX10.
Comment faire ? D'avance merci pour vos réponses.
Hello,
I bought a RAX10 router to create a separate network at 10.0.0.xxx from the main Livebox network (192.168.1.xxx).
Everything worked except that connected to the network at 10.0.0.xxx, I can ping the box which is at 192.168.1.xxx.
I would like no device to be able to access the network at 192.168.1.xxx.
That is to say completely isolate the network in 10.0.0.xxx distributed by the RAX10.
How to do ? Thank you in advance for your answers.
  • plemans's avatar
    completely isolate it? Unplug it.
    Otherwise if you want any data to pass, they need to be able to communicate a little.
    Otherwise you'd need to upgrade to a business grade solutions with vlans to isolate devices/subnets.
    • Philippe29's avatar
      Philippe29
      Thanks a lot for your answer.
      I can't unplugged it completely.
      Because the first one (192.168.1.xxx) give access to the web via WAN.
      Is it possible to configure a firewall in the RAX10 ?
      • plemans's avatar
        You could buy a seperate firewall that could do it. but not one in the RAX10. Its literally the most base model dual band AC mesh system netgear offered.
  • Question :
    Is the NETGEAR WAX204 able to do this ?
    I can find a concrete description of the exact functions.
    Thanks a lot
