11jar11
Mar 07, 2024Aspirant
RAX10 - I have a reset question.....
My router is connected to fiber. Ziply to be exact. I use the wifi for two laptops and a linux desktop. The only other connection is my Roku. I never changed anything regarding security. First I...
Mar 07, 2024Guru - Experienced User
Is there a problem that you need to factory reset?
Might give more details regarding if there is a problem.
Might try a full power OFF of the router for 1 minute then back ON as a simple first step to check for something.
- 11jar11Mar 07, 2024Aspirant
I don't have any problems just wanted to reset password and anything else to make the router safe. Don't want to screw up my Roku connection.
- microchip8Mar 07, 2024MasterYou don't have to factory reset the router just to change passwords. You can do that in the router's Web UI at http://routerlogin.net or http://192.168.1.1
