PlainCardboard
Dec 17, 2021Guide
RAX10 5Ghz signal strength and speed drop after QoS and channel change
Router: Nighthawk RAX10 4-Stream AX1800 Wifi 6 Firmware: 1.0.10.110 OS: Ubuntu LTS Turned on QoS, with the speed test reporting 329mpbs down, 107.27up and changed the 5Ghz channel from 44 to 36...
- Dec 18, 2021
Yes VLAN is enabled.
It's now confirmed that it's not the routers fault.
I started with a clean install of Ubuntu lts without any updates and everything went back to normal.
Signal strength shot up to excellent and link speed is at 433mbps always, speed test reports 130mbps download with 105mbps upload, and this is after I moved it back onto my desk where it is much further with more obstacles in the way than on the floor.
Thanks for your help!
Dec 18, 2021Guru - Experienced User
do you have the vlan enabled for the chorus?
How do I set up my NETGEAR router if I have Spark NZ Fibre or UFB? | Answer | NETGEAR Support
PlainCardboard
Dec 18, 2021Guide
- plemansDec 18, 2021Guru - Experienced User
Glad that fixed it!
