tophrob
Jul 28, 2021Follower
RAX10 (AX1800) Parental Control
 I'm looking to purchase a WiFi6 router with Circle Parental Control.  According to the below page from Netgear, Circle Parental Control is supported on the RAX10 (AX1800), however it's not mentioned ...
RamuNG
Sep 28, 2021Aspirant
Hi,
I recently purchased RAX10 because considering it supports smart parental control. I purchased online through AMAZON India on 20th sept. 2021.
After instlling Router and Nighthawk anroid app, I do not see parental control feature in the app.
I called your customer support today and got to know that the latest firmware does not support smart parental control.
When your official website is claiming it support but I do not see so in the real product.
Please respond and do help.
Thanks,
Ramu
DarrenM
Sep 28, 2021Sr. NETGEAR Moderator
Yes the RAX10 does support Smart Parental Controls. You may want to reinstall the Nighthawk app on your phone or test the app on another mobile device if able.
DarrenM
