regdab
Jun 22, 2021Aspirant
RAX10 AX1800 WI-FI 6 Router: "router password reset" warning when browsing websites
I keep getting this message when I try to browse various websites: "Router Password Reset. Access to this resource is denied, your client has not supplied the correct authentication. We can hel...
Christian_R
Jun 29, 2021NETGEAR Employee Retired
Hello regdab,
May you provide us with a screenshot for us to look into this further.
Christian
- regdabJul 02, 2021Aspirant
Thanks very much. Here's a screenshot of the message I get when i try to switch from our old Wifi to the new netgear one.
- Christian_RJul 06, 2021NETGEAR Employee Retired
Hello regdab,
Thanks for the screenshot. May you factory reset your router by holding down on the reset button for 15+ seconds using a pin/needle. You will need to run through the setup assistant again and you may do so using the Nighthawk app. Please let me know if your issue persists.
Christian
