Bijel's avatar
Bijel
Tutor
Nov 15, 2021
RAX10 Cannot connect MItel 5330 or 5320 for teleworking
I'm trying to setup my company's Mitel 5330 or 5320 phones that they have given to me for teleworking (they gave me the 5320 to try after the 5330 wasn't connecting). They have said everything looks ...
  • plemans's avatar
    Nov 15, 2021
    without knowing more about your actual connection to your isp, its a little challenging.
    You can try putting the router in access point mode. If the ISP has its own routing setup, it'll let that device control the ip address from the mitel. If it doesn't work, you'd need to factory reset the router to get back in.
