ramesh_iyer
Nov 21, 2021Aspirant
RAX10 drops signal on both wifi and wired connections
Hi, I live in Mumbai, India. I bought the RAX10 model WiFi-6 Dual-Band Router for my home use last weekend, and configured to use it yesterday. However, I have observed that this router drops signal...
Nov 22, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
- ramesh_iyerNov 24, 2021Aspirant
Thanks for sharing the links. I have posted in the section "Nighthawk routers with WiFI6 (AX) and WiFI6E (AXE) from the link shared by you. Hope someone responds to it soon.
