darryl1020
Jan 15, 2025Aspirant
RAX10 internet issues
Hi all, My netgear is unable to connect to my optus NBN after I had a storm last night. I have confirmed NBN itself is working. How can I address this please Refer to the photos attached
michaelkenward
Jan 16, 2025Guru - Experienced User
How does NBN deliver the Internet to you? What modem/ONT/gateway? Is that still working?
Storms are an excellent source of electrical spikes that can kill electronic kit. No amount of protection will protect your stuff from a short sharp voltage spike.
Troubleshoot starting at the plug in the wall.
Just another user with time on their hands.
darryl1020
Jan 16, 2025Aspirant
Thanks everyone, I have decided to return my unit via warranty and get another unit as I dont want to pay AUD150 for technical support from Netgear
- michaelkenwardJan 17, 2025Guru - Experienced User
Good luck there.
Warranty support isn't likely to cover storm damage.
Support here costs nothing, but you do have to provide a few more details and try some simple tests.
You may have to go through those hoops to persuade Netgear to issue an RMA.
