Erickkkkkkk
Aug 30, 2023Follower
RAX10 Router always can't get the WAN IP
Does anyone have the same problem like that? Disconnection occurs at least once a week. Then I login my router figure out the WAN IP, Subnet, Gateway is 0.0.0.0. After I reboot the router, it wil...
Kitsap
Aug 30, 2023Master
Erickkkkkkk wrote:Does anyone have the same problem like that? Disconnection occurs at least once a week. Then I login my router figure out the WAN IP, Subnet, Gateway is 0.0.0.0.
After I reboot the router, it will back to normal...every time.
A couple of pretty standard questions.
What is the firmware version number installed on your RAX10? The Latest is not a version number. Need the number to verify.
What is the brand name and model number of the modem/ONT connected upstream of your RAX10? Please look on the label.
