Erickkkkkkk
Aug 30, 2023Follower
RAX10 Router always can't get the WAN IP
Does anyone have the same problem like that? Disconnection occurs at least once a week. Then I login my router figure out the WAN IP, Subnet, Gateway is 0.0.0.0. After I reboot the router, it wil...
michaelkenward
Aug 31, 2023Guru - Experienced User
After I reboot the router, it will back to normal...every time.
The answer to that is likely to be in your answer to the question from Kitsap about the modem/router.
