Enniox
Nov 20, 2023Follower
RAX10 Smart Parental Control not available on Nighthawk app
Hello, I just bought a RAX 10 because support for smart parental control was advertised. However, I cannot find the activation option on the Nighthawk APP. Where can I find it? Thanks
michaelkenward
Nov 21, 2023Guru - Experienced User
iOS? Android?
On the main page for the router in the app.
Armor
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
