kbrock
Nov 12, 2023Aspirant
RAX10 stream from a KODI tv
I can not get this new router to stream from my computer thru the router to my KODI box. I use this stream my music collection mostly. My DLINK 1750 did this with no issues just plug and play. The ...
- Nov 13, 2023
Ok, problem solved. What are the odds that I took a windows update while I was installing the new router.
Turns out MS turned off file and printer sharing and discovery during a missed update.
Boy I hate Bill Gates....
kbrock
Nov 13, 2023Aspirant
Sorry I was not concise the router is ax1800 RAX10 brand new. The other router was an autofill.
I was not blaming the router but my dlink did do KODI streaning out of the box but it is getting unreliable.
I am sharing from a windows 10 computer with the music on a folder mymusic. The computer name is damor with KODI I used the SMB sharing to share this folder from the computer to my media player then to the receiver.
the SMB is not working on the netgear router, so I need a new way to connect.
My question is which one. This router does not have USB or ready share, at least I can not find it.
A few other network options on KODI
NFS(s)
UPNP
FTP(s)
web server directory HTTP(s)
The error is on KODI as I try to add my music(damor) connection not allowed.
I have edited the server network connection and change the SMB settings but no connection from media player to damor(my file server)
one of the solutions I found was USB readyshare but the option is not available on this router?
Thanks just let me know if you need more back ground.
kbrock
- michaelkenwardNov 14, 2023Guru - Experienced User
Good to know that it was nothing to do with the router.
