scotts2488
Sep 06, 2023Aspirant
RAX10
I keep having drop outs on my internet connection daily. My ISP says all is good on their end. Using Citrix and it disconnects several times a day. Is it the modem?
michaelkenward
Sep 06, 2023Guru - Experienced User
Not much to go on there.
What drops out? Internet? Wifi? Wired Ethernet? (Look at the LEDs on the router.)
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
