kawivukan
Nov 05, 2020Guide
RAX12 2.4 wifi issue
I upgraded to the RAX120 Nighthawk and had been running into issues with it not connecting to the 2.4ghz wireless network. Finally found a fix on here by disabling the 'OFDMA' Wifi 6 settings and eve...
- Nov 07, 2020
It should be fine, I've got OFDMA on and PMF and have some really old devices and no issues.
See if the reset helps and let us know.
Newfiedrool
Nov 06, 2020Virtuoso
What is not connecting to the 2.4 band.
Did you perform a factory reset to see if the issues are solved?
kawivukan
Nov 06, 2020Guide
Both my phone and laptop weren't able to connect to it. I haven't gotten a chance to reset the router but, hopefully that fixes it.
