penguinpages
Nov 15, 2021Tutor
RAX120 - Drive Shares Broken after drive change
Manufacture: NetGear Nighthawk AX12 AX6000 Model: RAX120 Firmware: V1.2.3.28 I had two usb drives with two shares: A1 port : Drive label and share name "backup" A2 port: Drive lable and s...
Razor512
Nov 16, 2021Prodigy
To better understand how it is handling the shares from a client perspective, using any folder, in the address bar enter in \\router IP
For example, if the router IP is 192.168.1.1, then to \\192.168.1.1
How does it list each share?
