kc6108
May 15, 2019Luminary
RAX120 - Dual WAN
I setup an RAX120 for a friend, and he's reporting some issues.
With WAN aggregation turned on he is seeing three issues that he wants addressed:
Under the Advanced tab, on the Advanced Hom...
kc6108
May 16, 2019Luminary
Would you verify my findings on Issue 1 and Issue 2 above? To test Issue 2 it would be best if you unplugged any cables from LAN ports 2, 3, & 4 and rebooted.
I know you are experiencing Issue 3 as we've discussed it in a previous thread.
- jimlenzMay 16, 2019Aspirant
I can confirm that Item #1 is the same for me, all 0's
On Item #2, I cannot reboot at this time but will have to do that later and will write back.
btw, I seem to have resolved my issue with QNAP and all connections .
As of now, this is what is showing for #2
