pjd813
Jul 01, 2022Guide
RAX120 - is there a software tool to watch the speed out of the router continuously?
Hi, My router seems to output the full speed that I’m getting from my ISP when I use Speedtest and others when I use both my iPad and my Windows laptop connected directly to the router by Ethernet. ...
- Aug 03, 2022
Tests like that are more tricky. For general tests, you could repeatedly run a speedtest.net test, but if you want a constant transfer, then the most reliable way to do it, is to have your own VPS that has a dedicated connection above 1Gbps ( or at least twice the speed of both your home WAN connection's upload and download speed, and then have it act as a iperf server. While more expensive, it is a more reliable way to measure a single connection's throughput over a more extended period of time without being influenced by other people using the same server to test throughput.
Though often a more common method of longer term test is running 3-4 speed tests in a row every hour throughout a day in order to keep track of how your WAN throughput changes over the course of a day. This is especially more useful for people on cable internet connection since the shared throughput nature has a higher degree of variability in the speed, and knowing it will impact how you go about implementing QOS, and various other functions.
pjd813
Aug 03, 2022Guide
For the purpose of testing I would have no problem if testing for an extended period of time (at least 30 minutes) to get full statistics would not allow other processing. It is a test.
Razor512
Aug 03, 2022Prodigy
