elelunicy
Sep 23, 2019Aspirant
RAX120 - Much slower speeds with AX enabled using an iPhone 11 Pro
So the iPhone is the first and the only Wi-Fi 6 client I have, and right now the wifi speeds are much slower with AX enabled (I'm on firmware V1.0.1.90). AX enabled: Link speed: 1201 Mbps, Down:...
avtella
Sep 23, 2019Prodigy
Can’t comment about the iPhone 11 but I have 3 laptops with the Intel AX200 WiFi internal card I can see up to a 10-20% gain on ax depending on location and signal. Mostly it’s similar in average to low signal situations. Only issue I’ve seen is that for me uploads can hit upwards of 1280+ Mbps but downlink throughout is like half of that when doing file transfers to and from my NAS or even the router’s USB storage.
As the phone is quite new it could be either a phone side issue or a compatibility issue between the two devices. File an issue report with Netgear.
