Alexjccim's avatar
Alexjccim
Apprentice
Jun 02, 2020
RAX120 - poor WiFi speeds
Hello There,   I purchased my RAX120 on April 22.  I replaced a R8500.  The Wifi speeds are horrible.  Can anyone suggest some diagnostics test or suggestions to trouble shoot this issue.  My entir...
  • Killhippie's avatar
    Jun 03, 2020
    Do a factory reset after updating, and did you turn on Bitdefender Armor? I and many others here get great speeds so it could be that the reset will help (its advised on big updates really) and failing that it may be settings or at worst hardware.
