inspiring
Jun 06, 2020Aspirant
RAX120 - Using AX Crashes Router
I recently got a new computer with Wifi 6 capabilities which uses the Intel AX201 module. At first I thought it was the motherobard, however I noticed that the router disconnects completely while pla...
Christian_R
Jun 10, 2020NETGEAR Employee Retired
Hello inspriing,
When you notice the router crashing while playing Valorant on your computer, are you able to access the internet with another device on the network?
Christian
- inspiringJun 10, 2020Aspirant
After I reset the router, I noticed it stopped crashing. Before it would some reason crash and then I could not connect on either devices.
- Christian_RJun 11, 2020NETGEAR Employee Retired
HI inspiring,
Thanks for the update Glad to hear a reset helped.Christian
