dontfeedphils
Aug 13, 2020Follower
RAX120 - VPN Server TAP/Bridge Mode?
Can anyone tell me if the RAX120 is capable of running as a VPN server in TAP/bridge mode?
I'm testing out a Asus GT-AX11000 and it has all the features I need (including a built-in OpenVPN server that can run in TAP/bridge mode) but like the last couple Asus routers I've tried to use I get constant drops and reboots on the 5GHz networks and I'm done playing wack-a-mole trying to figure out which one of their firmwares will work correctly.
I also tried the TP-LINK Archer AX6000 which I liked and had very solid wireless, but I wasn't sold on the firmware and the options it offered. I'm hoping the RAX120 might combine the things I like about both the GT-AX11000 and the Archer AX6000.
TIA!
1 Reply
- Christian_RNETGEAR Employee Retired
Hi dontfeedphils,
VPN service is disabled when running the router in AP mode.
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Christian
