robertoselmi
May 25, 2020Tutor
RAX120 + NIGHTHAWK® MESH WIFI 6
Is it possible to use a NIGHTHAWK® MESH WIFI 6 system connected to a RAX120 router to increase coverage? If it is, how?
Christian_R
May 28, 2020NETGEAR Employee Retired
Hi robertoselmi,
Yes, you can connect the Nighthawk Mesh system to a RAX120. You will need to set the Nighthawk Mesh system to access point mode to accomplish this.
Christian
- robertoselmiMay 29, 2020TutorIn this way the RAX120 publishes the SSIDs and the two non-wired mesh objects republish the same SSIDs, if I move from one place to another I keep the connection because the SSID does not change and I roam transparently. Correct?
- robertoselmiJun 08, 2020TutorAny response?
- Christian_RJun 10, 2020NETGEAR Employee Retired
Hi robertoselmi,
Ultimately it's up to your client devices to actually switch to the access points. there's nothing the access points can do to force the switch. However, generally clients will switch when they see a much stronger signal.
