robertoselmi
May 25, 2020Tutor
RAX120 + NIGHTHAWK® MESH WIFI 6
Is it possible to use a NIGHTHAWK® MESH WIFI 6 system connected to a RAX120 router to increase coverage? If it is, how?
robertoselmi
May 29, 2020Tutor
In this way the RAX120 publishes the SSIDs and the two non-wired mesh objects republish the same SSIDs, if I move from one place to another I keep the connection because the SSID does not change and I roam transparently. Correct?
robertoselmi
Jun 08, 2020Tutor
Any response?
- Christian_RJun 10, 2020NETGEAR Employee Retired
Hi robertoselmi,
Ultimately it's up to your client devices to actually switch to the access points. there's nothing the access points can do to force the switch. However, generally clients will switch when they see a much stronger signal.
- robertoselmiJun 10, 2020TutorHi Christian,
I understand, my question is more related to the efficiency of the mesh system, the management is shared between the three devices, so the association of the mac address is orchestrated, or is it only between the two meshes?
Regards
