wdenny01's avatar
wdenny01
Follower
Mar 03, 2021
RAX120 + Wyse Terminal
We have a wyse Terminal that works great with a R7800 router, I purchased a RAX120 and tje wyse terminal will not get a ip address from the router and if we assign a ip address to the router it cannot logon to our company, what is blocked and how to unblock the Wyse terminal
Thanks
1 Reply
  • schumaku's avatar
    schumaku
    Being an old crow I was buffed about the Wyse termial term (typically serial lines, or twinax for big blue) ... but guess you talk of some later Wyse thin client.
    Can we assume this unspecified Wyser terminal is configured as a DHCP client?
    The Ethernet link is coming up (I hope there are some indicatros on the Wyse unit, too)?
    Until to this point I can follow you.
    Here I'm fully lost on how you use this router, and for what kind of a connection you use the Wyse terminal. Is the host on the same local network, or on the Internet?
