Shahrum
Mar 29, 2020Aspirant
RAX120 1.0.1.118 on gigabit fiber getting max of 150mbps/500mbps on wifi 5ghz
I've read an extensive amount of older posts but haven't seen any particular comments on firmware 1.0.1.118. I recently purchased a RAX120 that I'm running directly off of CenturyLink gigabit service...
Topology
Mar 29, 2020Virtuoso
Shahrum, have you confirmed that “AX” is enabled on the RAX120 (see BASIC | Wireless | Enable AX)?
- ShahrumMar 29, 2020Aspirant
Topology wrote:Shahrum, have you confirmed that “AX” is enabled on the RAX120 (see BASIC | Wireless | Enable AX)?
Thanks for the quick reply!I do have it turned on as well as ODFMA on both 2.4 and 5ghz.
- Christian_RApr 07, 2020NETGEAR Employee Retired
Hi Shahrum,
May you check to see if disabling AX has any improvements.
Thanks,
Christian- ShahrumApr 07, 2020Aspirant
I just did a test and the speeds remained unaffected. So it didn't get better or worse.
