Jim1590
Feb 08, 2022Star
RAX120-100N Reboots
Purchased a Nighthawk RAX120-100N yesterday at Best Buy. It is randomly rebooting. My XR500 in same location did not have this issue. I am plugged into a APC UPS system. It has rebooted 3 times i...
- Feb 08, 2022
If that doesn't help, I'd exchange it at where you got it.
Maybe you got a sketchy one or one with a bad power supply. It'd be faster to exchange than go through support/rma.
Jim1590
Feb 08, 2022Star
I will do that tonight after work. Hoping to have a "to-do" list from here of steps to take.
Feb 08, 2022Guru - Experienced User
- Jim1590Feb 08, 2022Star
I am on firmware version:
V1.2.3.28
My wife said it worked fine today and she was home with the TV on (hulu) without issue. I will keep an eye on it over next few days. If it happens again, will do the reset. After that, will bring it back for a different one.
Thanks
- Jim1590Feb 10, 2022Star
So, the steps that I took after it acted up yesterday during the day.
Set fan to on all the time and stood it up on its front end to maximize airflow in case it was a overheating issue. Also stepped down the signal speeds by 1 to reduce power usage. This was night before last and did not help during the day.
Did a reset but not factory. Wife had a zoom meeting to jump on and didn't have much time to kill. Had 1 power cycle during the 30 minute call. Also put a switch behind it for the ethernet cords going into the back (desktop, philps hue bridge, magicjack). Trying to minimize demand on router.
Did a factory reset and set up the parameters again (SSID, password, 3 static address). Fine for about 2 hours and then rebooted while watching Disney +. Ignored it, 5 minutes later rebooted.
Removed power cord from back of UPS and into the wall. 30 min later, rebooted.
Factory reset, unplugged, put into box. XR500 put back in the same place. Ran all night without issues. Now need to decide if I want to stick with Netgear or try another brand like Linksys or Asus.
- plemansFeb 10, 2022Guru - Experienced User
Sad to see it not work. Its a solid router.
Kind of up to you what route to go.
I get a little biased but its because I only see the ones with issues on here. Its not usually the ones saying how great something is :)
I'd try exchanging it if you bought it locally. Most manufacturer's have a certain percentage that have issues straight from the factory. If you're going to see issues on a devices, its fairly quickly after buying.
but if it put a sour taste in your mouth, try something else. I've had great luck with Asus and some Tp-link devices.
I have no concerns sticking with Netgear. Probably gone through 10 of their routers on my home setup (going back to a N100) and have set them up for family and 2 for my work.
Pretty sure I grabbed the last AX6000 on the shelf when I was there (Best Buy), I was looking for the AX6600. That was out of stock. I will return it tonight and can order a new one from their website.
Any real world difference between the AX6600 and the AX6000 that should steer me one way or the other?
If I have another failure, I will look at the other brands.
Thanks
