roythk
Jul 02, 2019Tutor
RAX120 5G wifi suddenly missing
i am using RAX120 router, and already disable AX mode. Sometime the 5G wifi will suddenly disappear lost the connection but 2.4G still can see can connectable. Need to wait around 1mins like reboot...
- Aug 22, 2019
The problem fixed when i upgraded to lastest firmware and reset the router.
Maybe you can try to reset the router after upgrade the firmware
Cman60
Aug 22, 2019Aspirant
I am having the exact same issue. I have to switch to 2.4 then back to 5ghz. in order for visibility to return. I have AX mode disabled as well. I believe I have the newest FW version.
roythk
Aug 22, 2019Tutor
