BillyBinhSVT
Oct 05, 2021Follower
RAX120 5ghz problem
WIFI 5ghz see & can not SYNC it is FIRMWARE problem FW: & bug 1.0.1.128= work ok ( direct JUMP update to 1.2.2.24= 5ghs wifi FAIL) Update è 1.2.2.24= Fail 5Ghz wifi (no sync) Downgrad...
Oct 05, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
