theycallmerayj's avatar
May 12, 2021
RAX120 and CM2000-100NAS with Xfinity 1.2gbps tier - possible to get full speeds?
Just upgrade to xfinity's new tier of 1.2gbps. I already owned the rax120, but went and bought the CM2000 knowing I needed it to hit higher speeds. For the life of me I can't figure out how to get th...
  • plemans's avatar
    May 13, 2021
    the rax120 does wan port aggregation and the sb8200 supports port aggregation as well.
    That'd give you >1gig speeds without needing a new modem
    Solved: RAX120 WAN Port Aggregation To CM1200 - NETGEAR Communities
    the only thing I'd caution is the sb8200's port aggregation is sketchy at best. I've got one and had nothing but issues with it using port aggregation.
