Hyperflasch
Mar 07, 2020Follower
RAX120 and Firtzbox 6590 Cable WAN aggregation possible ?
Is there a possibility to bundle 2 Ports of the Fritzbox to get higher Bandwith ? The Ports of the Fritzbox are just 1 GB and i want faster connections by wire, cause my PC and AX got 2,5, GB Ports. ...
Mar 09, 2020Guru - Experienced User
The fritzbox 6590 doesn't off lan/wan aggregation. so it won't work
