mv8167
Apr 04, 2020Tutor
RAX120 and Mesh x65 extendar
Will the x6S mesh extender work with my new RAX120 router?
Apr 05, 2020Guru - Experienced User
should work fine.
I recently fired my EX8000 back up and connected it to my RAX200 for testing and it works great.
mv8167
Apr 15, 2020Tutor
It seems that when I confjigure my extendar, about 50% of my devices stop being connected. They just loose there current WIFI connection. Especiallyn my Alexa devices. Anyone have this issue too? Can Netgear tell me if these two devices have been tested together?
- plemansApr 15, 2020Guru - Experienced User
Again, i don't have the RAX120 but I've ran my RAX200 and EX8000 for a while. No issues with alexa devices or google home devices.
What firmware is on each one of them?
and what modem are you using?
- mv8167Apr 15, 2020Tutor
Both have the latest firmware and my modem is from ATT UVERSE. I have reset both soft/hard and hjave tried a few old firmware versions. I am having issues with my new roouter dropping the WUIFI signal or not sending one out at all.
- plemansApr 16, 2020Guru - Experienced User
Att is known for using combo devices. That means they have a router and a modem integrated together. And att is also known for their passthrough/modem only modes not functioning correctly.
do you have your RAX setup in AP mode?
