mv8167
Apr 04, 2020Tutor
RAX120 and Mesh x65 extendar
Will the x6S mesh extender work with my new RAX120 router?
Apr 16, 2020Guru - Experienced User
Att is known for using combo devices. That means they have a router and a modem integrated together. And att is also known for their passthrough/modem only modes not functioning correctly.
do you have your RAX setup in AP mode?
mv8167
Apr 22, 2020Tutor
Not sure what AP (Access Point) mode is but I use my router is set up as just a WIFI router for home use. When I add in the extender, starting from ground zero, my WIFI signals become very unstable. The Amazon products seem to get disconnected while other devices disconnect randomly. Using the RASX120 seems to disconnect and drop signals randomly also, so it could be the overall culprit.
