TheScionx
Feb 05, 2020Follower
RAX120 andVPN Service
 Can the RAX120 use VPN services such as ExpressVPN or NordVPN?     If so, it is a firmware update or a manual configuration?     If it is manual, how can it be done?     Thank you in advance for any ...
Shahinvania
Feb 29, 2020Initiate
I can't believe this high end device doesn't have the option to use ExpressVPN... Hope that will change soon! Where can I sign a petition so netgear changes that awful situation?
avtella
Feb 29, 2020Prodigy
I have a sggestion filed in the ideas section of the forum about this, upvote it if you want.
- michaelkenwardMar 01, 2020Guru - Experienced User
Link?
I could not find it.
