Filecon
Oct 09, 2020Follower
RAX120 AP Aggregation and internet loss
I just installed a RAX120 as an AP. my setup is ISP ->SAGEM Modem -> GS516T Switch -> RAX120
Whenever I put in the ip address in my browser to change the setup of the RAX120, I lose internet access on the RAX120. I'll do a factory reset, set it up again as AP, then it works. As soon as i put the ip address in my browser to change the settings again, I lose Internet connection again. if I access the RAX120 through the Nighhawk app on my iphone, it's ok. only problem is, I can't change the settings I want through the app.
In addition, I want to set up aggregation on the RAX120 in AP mode, but the WAN and LAN and faded out in the setup and I can't set it up. Does anyone know why?
Thanks in advance.
1 Reply
- Christian_RNETGEAR Employee Retired
Hi Filecon,
What firmware version is your router on? You may check to see if your device is due for a firmware update. Suggestions made by plemans in the post below may help as well.
Christian
