Often
Jun 05, 2020Tutor
RAX120 Apple TV 4k issues
I'm having a big issue with my RAX 120, but with only 1 device in my household. I have a pretty simple network. I'm on ATT Fiber 1000 with their BGW210 gateway setup in IP passthrough mode, so there...
jndassaro
Nov 20, 2020Aspirant
Having exactly the same issues. I have been trouble shooting for months with no luck. It’s definitely a Netgear issue. My friends cannot replicate the issue on their networks with my Apple TV 4K.
- JoeMorNov 21, 2020Tutor
AppleTV 4K does not like these new routers running in Wifi 6 mode even if they are backward compatible. You have to disable Wifi 6 (SmartConnect) in order for it to work. I am not doing it and just waiting for AppleTV 4K to support wifi 6.
Another option is to by the EAX80 wifi extender and place it by your AppleTV 4K and connect to it via Ethernet. I purchased the EAX80 and it works great with the RAX200. It is something to think about. I am going to forgo purchasing an AppleTV 4K device because the new Sony smartTVs that are coming out include the Apple App. So, no need for a AppleTV 4K device anymore.
- OftenNov 21, 2020TutorIt still did it even with wifi 6 off.
Do you live in an apartment with 20 other households having wifi routers? If so, Netgear wanted me to pick a wifi channel instead of selecting Auto for the setting as well. When I heard I had to disable SmartConnect that was a, no way, response from me. Try setting the individual 2.4, 5.0 antennas to a channel that is not being used. How to determine if a channel is not being used? Well, I guess if someone else is using the same channel, then you would see network disconnecting/attaching problems. I am not sure about this last point.
