Often
Jun 05, 2020Tutor
RAX120 Apple TV 4k issues
I'm having a big issue with my RAX 120, but with only 1 device in my household. I have a pretty simple network. I'm on ATT Fiber 1000 with their BGW210 gateway setup in IP passthrough mode, so there...
Often
Nov 21, 2020Tutor
It still did it even with wifi 6 off.
JoeMor
Nov 21, 2020Tutor
Do you live in an apartment with 20 other households having wifi routers? If so, Netgear wanted me to pick a wifi channel instead of selecting Auto for the setting as well. When I heard I had to disable SmartConnect that was a, no way, response from me. Try setting the individual 2.4, 5.0 antennas to a channel that is not being used. How to determine if a channel is not being used? Well, I guess if someone else is using the same channel, then you would see network disconnecting/attaching problems. I am not sure about this last point.
- OftenNov 21, 2020TutorNope, a house. I live in a neighborhood and there's a decent number of signals, but there's enough space in the channels.
Considering the appletv was the only device doing it, and my Nvidia Shield doesn't after I switched to it, there's something strange going on in the communication between the 4k apple tv and the router. My older Apple tv doesn't have the same issue stiff.- JoeMorNov 21, 2020Tutor
Yep, you are seeing the exact same issue I was seeing. My AppleTV 3rd generation works with the Router. But, the latest AppleTV 4K does not.
BTW, I hate Netgear customer support. They spend most their time trying to close your support case then actually trying to help you. Horrible customer support. Horrendous customer support. Did I mention I did not like Netgear customer support?
