krestrazh
May 13, 2020Tutor
RAX120 Attached Devices Not Showing All Devices
Firmware Version 1.0.1.122 does not show all of the active devices on my network. I downgraded to 1.0.1.118 and everything shows up. In 122, it does not show my work laptop, running Windows 10, but c...
Christian_R
May 15, 2020NETGEAR Employee Retired
Hello krestrazh,
May you try performing a factory reset on your router and running through the setup assistant again.
Thanks,
Christian
krestrazh
May 16, 2020Tutor
I also did a factory reset and reconfigured without restoring from backup. While it did make one more device show under Attached Devices, my Android TV device still does not.
