Christos84
May 01, 2020Aspirant
RAX120 Best channel for higher speeds with 5G
Can someone help me with how to find the best channel for my 5G AX speeds?
You have a problem of some sort?
These things are best left to the devices to decide. Unlike 2.4 GHz it isn't likely that you will see interference from the neigbours.
And speed is down to the wifi clients.
- Christos84AspirantI have Fios 1G up/down. When close to the router i get a little above 600mbps down and 500mbps up. I have the 5G wifi set on channel 36. Should i be happy with the speeds im getting wirelessly or i can do better?
Christos84 wrote:
I have Fios 1G up/down. When close to the router i get a little above 600mbps down and 500mbps up.If that is wifi speeds, then you will never get Gbps. Even wired connections will lose some speed.
600 Mbps is faster than many wifi clients can deliver. The wifi clients you use are the key. You don't say what they are but can they get faster speeds on other wifi sources?
Is there anything you do that is too slow? Or are you just looking at the numbers?
