Christos84
May 01, 2020Aspirant
RAX120 Best channel for higher speeds with 5G
Can someone help me with how to find the best channel for my 5G AX speeds?
michaelkenward
May 04, 2020Guru - Experienced User
Christos84 wrote:
I have Fios 1G up/down. When close to the router i get a little above 600mbps down and 500mbps up.
If that is wifi speeds, then you will never get Gbps. Even wired connections will lose some speed.
600 Mbps is faster than many wifi clients can deliver. The wifi clients you use are the key. You don't say what they are but can they get faster speeds on other wifi sources?
Is there anything you do that is too slow? Or are you just looking at the numbers?
Christos84
May 04, 2020Aspirant
Just looking at the numbers. Im doing Speedtest with my iPhone 11Pro. I have connected all my smart plugs and google home mini to the 2.4G channel and i only use the 5G for our phones and laptops and AppleTV.
