Feb 20, 2020Guru - Experienced User
RAX120 Beta Firmware
If you've got a RAX120 and want to try out some beta firmware or are having issues and want to try the new beta firmware, private message Christian_R and Christian will give you access to the forum/f...
Topology
Feb 20, 2020Virtuoso
Plemans, can you kindly post the list of (a) New Features and Enhancements and (b) Bug Fixes included in the RAX120 beta firmware?
Thank you.
You'll have to message christian for access and details. There's a non-disclosure with beta firmware. And then you can get the specific details on the beta post with the firmware. That's why you need to get approved. You don't have to install it should you choose not to.
- TopologyFeb 20, 2020Virtuoso
Plemans, thank you for the prompt reply.
Just a guess, but I suspect that the new RAX120 firmware will include (among other enhancements) a fix for the security certificate issue (see Why am I getting a security warning when I try to log in to my Nighthawk router?)....
- TopologyFeb 22, 2020Virtuoso
A firmware update for the RAX120 has been released: RAX120 Firmware Version 1.0.1.118 - Hot Fix
The update appears to address the security issue described in this article: Netgear under fire after TLS certificates found in firmware -- again
Note that the firmware version check in the browser interface fails to detect the existence of the new firmware, reporting "no new firmware.” Thus, it is necessary to download the firmware and manually update.
P.S.: Plemans, is this the new firmware that you referenced in your original post in this thread?
- plemansFeb 22, 2020Guru - Experienced UserNo.....
