begoldar
Mar 23, 2023Follower
RAX120 BETA Firmware
Hi Everyone, I'm looking to get a copy of the BETA firmware discussed on multiple forums to fix my intermittent wifi issues. Thanks!
HARDWARE: RAX120
FIRMWARE: V1.2.8.40
SERIAL: 5VE
1 Reply
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, Smart Parental Controls or Circle, Traffic Meter.There is no beta FW for v1 RAX120's. Beta mentioned is for only v2's with random reboot issues. Doesn't solve any wifi problems.
