blackart
Sep 06, 2021Aspirant
RAX120 bridged slow 5Ghz wifi speed
ISP plan: 1000M Router Firmware Version V1.2.1.22 RAX120 work as bridge mode as the following: Main router(asus) <-----wifi 5g------> RAX120 <-----cat8 cable------> PC 5ghz: PC got ...
- Sep 06, 2021
thx for your reply.
My problem is fixed. I turned off Main router's 5ghz AX function.
My PC now get 500Mb.
Sep 06, 2021Guru - Experienced User
What speed do you get if you connect the rax120 (in access point mode) to the Asus and test its speeds?
curious if there's an issue with the 5ghz or possible with it being in bridge mode.
- blackartSep 06, 2021Aspirant
thx for your reply.
