ljy
Jan 06, 2020Aspirant
Rax120 can't working in HT160!
My rax120 was bought last month, Because I use ac9260 wireless network card, so I choose to work in ht80, there is no problem with the device. But just yesterday I changed the ax200 wireless network ...
Jan 06, 2020Guru - Experienced User
A couple things to try.
1. Make sure the intel card has the latest drivers from intel.
2. Just because its connecting at 1gbps doesn't mean the RAX isn't broadcasting 4800mbps. If you're further away, somethings obstructing, dfs is making it switch because you live near an airport, many factors influence your connection to the router.
3. The AX200 is a 2x2 device so its absolute max connection speed is going to be 2400mbps if everything is working correctly.
4. How far from the router are you? House materials?
- ljyJan 06, 2020AspirantMy intel wireless network card driver is the latest version of v21.60.2.1. My home is about 25km away from the airport, I don't think it will affect the router's work. My laptop is about 1-2m away from the router, and there is nothing in the middle. I can even see that the router uses 8 channels in the management interface. When I reconnect, I can get 2.4Gbps speed, however after 15s, the speed will drop to 1Gbps. I have also tried to reduce the firmware version, such as v1.0.0.84, but the problem also exists.
