mondenath
Mar 21, 2021Prodigy
RAX120 CONCURRENT HT160 AC/AX CONNECTION
Does the RAX120 support both ac and ax concurrent on HT160 mhz with max throughput of 1733 and 2400 .
It just need 4 for each client to get max but is that HT160 is support on ac as well and will it be can work concurrently.
- Christian_RNETGEAR Employee Retired
Hello mondenath,
I'll forward this inquiry to the team and get back to you as soon as I can.
Christian
- mondenathProdigy
I am waiting to hear back. Low range and high range concurrent access in mixed ax/ac/ mode .
- mondenathProdigy
https://www.netgear.com/images/datasheet/networking/wifirouter/rax120v2.pdf
As per datasheet what is highlighted yellow condition means . Its not clear.
