mondenath
Mar 21, 2021Prodigy
RAX120 CONCURRENT HT160 AC/AX CONNECTION
Does the RAX120 support both ac and ax concurrent on HT160 mhz with max throughput of 1733 and 2400 . It just need 4 for each client to get max but is that HT160 is support on ac as well and will...
mondenath
Mar 29, 2021Prodigy
So the internal team is not aware of or still figuring out the answer for simple query
Christian_R
Apr 13, 2021NETGEAR Employee Retired
Hello mondenath,
The RAX120 can support 11AC and 11AX HT160 at the same time. When the RAX120 is set to HT160, it will have only 4 streams. If the WiFi client only have one atenna(1x1), the router can support 4 clients HT160 by MU-MIMO. The total throughput can be higher than 1773/2400. However, each client will not be able to get max 1733 or 2400.
Christian
