BobSwitz
Aug 15, 2021Aspirant
RAX120 Configuration and firmware
Greetings, Does anyone have firmware ver. and configuration settings that work well all I want is screaming fast wifi with no buffering? I have spectrum with 400Mbps. I just purchased the RAX1...
BobSwitz
Aug 16, 2021Aspirant
Thank you for the suggestion I will try it this weekend when I get home.
I also noticed every morning when I check the log it says up time for the router is anywhere from 1hour to 3.x hours I don't believe it should be going down every night.
Thanks again.
Bob
thehypnootoad
Aug 18, 2021Luminary
Whats the log saying so can tell if its not a isp drop from modem or a router reboot. Usual questions & answers.
Are you on the latest firmware? If so how did you upgrade did you try a pin hole reset ?
- BobSwitzAug 19, 2021Aspirant
Even if the ISP did drop that wouldn't necessary cause the router to reboot would it?
I can't check this till the weekend.
Thanks for the help, Bob
- thehypnootoadAug 22, 2021LuminaryNot normally but it is Netgear if that carries on I would try a pin hole reset and see if that sorts it if not try reinstalling software again via lan (ethernet) then when all up running do another pin hole and start fresh.
