Splitr
Sep 12, 2023Tutor
RAX120 Connection to Zen full fibre FTTP(UK)
Hi all, I have a new Zen full Fibre FTTP connection in the UK. I would like to use my RAX 120 router and do have it working (ish) on IPv4 with zen; although the connection does seem to drop quite...
- Sep 12, 2023
I'd ask the ISP for help on this to ensure there ISP Serices and PPPoE account information and configuration is set correctly ON the router. Ask them for help and information on IPv6. Ensure they natively support IPv6 and ask about which protocol they require. DCHP, Static, 6to4, 6RD, etc. They should know how to get it working right.
Splitr
Sep 13, 2023Tutor
Hi,
I thought I'd just follow up on this in case anyone else has the same issue. Basically I checked with Zen and you have to ask them to turn IPv6 on, which they do immediately, no charge. As soon as they did, all I had to do is reboot the router and all the settings in the original post worked.
The general instability of the connection on IPv4 turned out to be a cabling issue. I had a 40m Cat5e going to the study with a NAS. When I upgraded the internet connection to basically Gbs it must had reached it's limit. Stung 50m of Cat8 over the roof and Rax 120 router handles it with ease.
I would recommend Zen BTW, they have great customer service.
