kschroed
Mar 09, 2020Star
RAX120 Connectivity Issues
I setup a new RAX120 ~4 weeks ago updated to latest firmware available V1.0.1.114. Device has been working great without any issues since I got it installed and all my devices cut over. Yesterday all...
kschroed
Mar 09, 2020Star
Yes it is double natted. I haven't tired either suggestion as that is a supported cofiguration as far as I know and was working just fine.
Mar 09, 2020Guru - Experienced User
kschroed wrote:Yes it is double natted. I haven't tired either suggestion as that is a supported cofiguration as far as I know and was working just fine.
so you know its in a double nat. Which is known to cause issues.
But someone told you "its supported" and "its worked fine". so it must not be the issue.
And you're not willing to try the methods that fix double nat's because "it must be a router issue".
Ok. Maybe it'll fix itself. Either way, good luck.
