kschroed
Mar 09, 2020Star
RAX120 Connectivity Issues
I setup a new RAX120 ~4 weeks ago updated to latest firmware available V1.0.1.114. Device has been working great without any issues since I got it installed and all my devices cut over. Yesterday all...
Killhippie
Oct 17, 2020Prodigy
Have you tried a factory reset are re-installing the firmware? I have had the router since October and have no issues like you, I update via a PC and not let the router auto update, then factory and reset the router manually, dont use a saved config file to restore from as that could bring in low level code from from the last firmware which may be causing issues.
Placesandspaces
Oct 17, 2020Apprentice
Additionally I have never been a fan of the ISP’s equipment (in this case the Spectrum modem). Cable companies generally supply customers with inferior equipment. I would recommend buying your own modem and maybe get one that is Docsis 3.1 compatible to future proof for higher speeds that are becoming more random more available. More cost effective too in the long run.
